Which version of Creo Illustrate is currently supported for the latest version of Vuforia Studio
ptc-1155647
7-Bedrock
@AmandaZupfer
Previously, it was mentioned that Creo Illustrate 8.1 and below were supported for creating sequences in Vuforia Studio. Could you please confirm which version of Creo Illustrate is currently supported for the latest version of Vuforia Studio (9-24-7)?
Regards
Paul
2 REPLIES 2
Hi @ptc-1155647,
so one point mentioned in the  Help  What’s New in Vuforia Studio 9.24.0  :
  • Creo files are now supported up to Creo 11.0
So far when Creo 11 is supported as CAD format that indicates that at least Creo Illustrate 11 is supported.
I was not able to find any statements else pointing on the supported version.
I myself currently  use Creo Illustrate 11.1
since it was released and I did not identified an issue but anyway what should work is with Creo Illustrate 11.0
Hello @ptc-1155647
You have a response on your topic. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
