Is there a way through scripts to call an experience from within another experience
thnx
I found the Solution. 🙂
if someone needs the solution here.
$scope.load=function() {
window.location='..URL of Experience'
the url of experience , use that in Experience Sharing.
BYE
BYE
also this will work. You need to check on the different devices - but think to remember that on one device the location was not working / but not sure -
$scope.openUrl=function()
let url= "https://www.bing.com/"
// here instead of this link used the deep link which is provided by experience share menu of the project
window.open(url)
As url here use for the url / variable value - the deep link which is provided by the menu Share>Share Experience > copy of the project which you want to open.
Addional your device need to be configured to associate the link with the Vuforia View
