can bind multiple events with single property of a model? if yes then how ?
Anil_vuforia
3-Newcomer
1 REPLY 1
Not completely sure of the question.
But you can drag the little binding handle to more than one thing. Let's say you have a slider widget. You can drag the value from that to multiple items (drag and drop one at a time, there is no multi-select) and they will all get the value from the Widget.
