cannot start server
michele1
2-Explorer
cannot start server
salve, ho un problema con l'installazione di Vuforia studio: quando eseguo l'installer, esso installa correttamente vuforia studio, ma appena termina l'installazione e tenta di avviarsi rimane bloccata questa schermata:
hi, I have a problem with the installation of vuforia studio: when I run the installer, it correctly installs the studio vuforia, but as soon as the installation finishes and tries to start it remains locked this screen:
2 REPLIES 2
Prova a vedere cosa ti dice il file di Log , oppure postalo per vedere di cosa si tratta.
Try to see what the Log file tells you, or post it to see what it is.
As @Giuseppe_Fiore mentioned, the log file may have some helpful information. Are you able to add it to this post? My guess is that you may have something else running on port 3000 that is causing Studio to not start.
