dynamically add model target through generator
  • February 10, 2024
  • 1235 views
I am working on my Master's degree thesis and :
I have a trouble finding out if newest vuforia is somehow allowing user to dynamically (for example in script) add new Model targets to recognize.
I am using Unity with vuforia library.
As far as i understand it i have to create a database and train it with my models, If i want to add or delete a target I need to delete and create a new database.
So is there a way to create an application with vuforia that will be able to run on its own and i will be able to change the database in app and it will take that dabase's models?
Or it's static and i have to do it manually and rebuild the app?
Hi @GS_10950937 ,
the concept is very exciting! But currently we do not support  this in the current functionality of  Vuforia Studio, So far I know in Vuforia Studio we have only fixed widget structure. - exception tmlText widget - which could generate dynamialy widget on load time - but it is not offical supported for enduser - solution should be  prepared from R&D and PTC consultings teams.
So at the end it  means you have only widgets which are already defined and could not be changed any more when the View container widget is loaded. So also on the end device we have some additional restrictiosn so that such changes in the widget structure  will be difficult to be achieved  at the current time.
But looking more detailed on your question - want to mention that  Vuforia Studio is a different product which indeed  based on Engine but not related to unity ... This communty is related to the products  Vuforia Studio , Vuforia Capture /Editor and Vuforia Chalk
So regarding Unity and Vuforia Engine this is possibly not the correct place to post  your topic and I want to refer  to this forum:
https://developer.vuforia.com/forum
which is possibly the correct location for this topic.
the related docs for model target are:
https://developer.vuforia.com/library/objects/model-targets
https://developer.vuforia.com/library/objects/model-target-generator-user-guide
https://developer.vuforia.com/library/model-targets/model-targets-supported-objects-cad-model-best-practices
https://developer.vuforia.com/library/model-targets/advanced-model-target-databases
and to download the Vuforia Engine tools
https://developer.vuforia.com/downloads/tool
because you mentioned that you interested on some automatic workflows -so possibly this info will be helpfu:
Model Target CLI
Use the command line interface (CLI) of the Model Target Generator to integrate the software into automated workflows and toolchains.
The Model Target CLI allows for Model Target generation in scenarios where the entire process needs to be either automated or done with stricter usage guidelines and data protection, i.e., preventing uploading any CAD data..
See also Model Target Web API for alternative interactions with the Model Target Generator.
https://developer.vuforia.com/library/model-targets/cli
but as mentioned you need to post you question to the forum for engine
Thanks , BR
