help install vuforia studio
MS_9601516
2-Explorer
Hola necesito ayuda quiero crear una experiencia en vuforia studio para un proyecto escolar pero tengo problemas para conseguir el programa vuforia studio tengo una version pero no me da la url de la experiencia para poder publicar mi experiencia
3 REPLIES 3
Hi @MS_9601516 , unfortunately my knowlidge for spanish like zerro so translated it here:
I need help I want to create an experience in vuforia studio for a school project but I have problems to get the program vuforia studio I have a version but it does not give me the url of the experience to be able to publish my experience.
I hope  the translation is OK. Based on that I beleive the quesiton is more basic quesiton you need to check that points
https://support.ptc.com/help/vuforia/studio/en/#page/Studio_Help_Center%2FCoreComponents.html%23
https://support.ptc.com/help/vuforia/studio/en/#page/Studio_Help_Center%2Fcommon%2FSecurity_Architecture.html%23
https://support.ptc.com/help/vuforia/es_install/en/
https://support.ptc.com/help/vuforia/es_install/en/#page/ES_Install_Help_Center%2FThingServerInstall_Welcome.html%23
I hope the link you can use to get the required information.
with view words I try to summeraze : you need 3 componets:
- Vuforia Studio UI  -> where you could create your proejcts - that is the first component required to develop your application
-when you complete the project you need to pubush it to an Experience Service
  the experience Servcie is the second component. That could be installed on premisses  means localy in your companies enviroment. In this case you need to download it from the PTC support side https://support.ptc.com/appserver/cs/software_update/swupdate.jsp
... or you can use  alternatively PTC cloud envirment - In that case you need to have a contract with PTC  - so that PTC will provide that Experience Service in a PTC cloud. Possibly your organization already uses such solution  - for that you need to check that with the local IT Team
- at the end when the project is published succesfully to the Experience Service you can then use the Vuforia view app  on the end device. With the Vuforia View app -the 3 component ,you can start your AR applicaiton.
The detail is that it does not give me access and I have in mind that there is an option for a free trial
Hi @MS_9601516 ,
unfortunately the trial option was retired still 15 May 2022 and is not provided by PTC any more. The announcement was the Vuforia Studio comminity on 12. April https://community.ptc.com/t5/Vuforia-Studio/The-Vuforia-Studio-Free-Trial-is-Retiring/m-p/789775#M10752
Possibly you  can ask if you have some a contact person of PTC presales or Sales or  PTC partner so possibly they could add an  user account for some tests on their server on the PTC cloud portal or if they on premisses server installation.
