I am playing sequence on one button ,after playing if i am switching to another button to show my bom at that time my sequence model is still showing .
i want to deactivate the sequnce .
You can use a timeout function for that sequence. Below is a sample code:-
$scope.sequence1 = function() {
$scope.view.wdg['model-1']['sequence'] = 'l-Creo 3D - ShoulderReplacement.pvi';
$timeout(function() {
twx.app.fn.triggerWidgetService('model-1', 'playAll');
}, 2000);
$scope.$watch('app.params.foo', function(val) {
if (val === 'true' || val === true) {
$scope.sequence1();
}, 2000);
} else {
$scope.sequencestop();
}, 2000);
$scope.sequencestop = function() {
twx.app.fn.triggerWidgetService('model-1', 'stop');
}, 2000);
as i do not have a coder background so understanding the code was an issue ,
I have applied this code but it didnt worked .
my problem is -
after playing the sequence when i switch to bom the parts which are created as model item gets hide but my model does not get hide(in the model there are parts which i do not want to show in my bom).
