I have a pvz file I created in Illustrate. I have 3 figures there – 3 different annimations. I can not get them switch in TWS. I tried to use this technique: https://community.thingworx.com/message/55252#55252 but it does not switch…I am on TWS 8.1.1
Hi Dmitry. Which approach did you attempt to use? Could you please share the steps you followed and the code you used?
