I want to use value change event of select widget,but tried with servral times and get nothing.Does any body tried with it?
the question has been solved,pls refer to the former link for detail.
I also post it to Mr Clay at below:https://community.ptc.com/t5/Studio/What-is-the-format-for-quot-List-quot-in-the-Select-widget/m-p/550949#M3300
pls refer to the attatched exported file for the detailed code.
