vufforia studio installation error
venkatesh
2-Explorer
[2019-01-11T10:17:00.671Z] Status Message: Getting ready...
[2019-01-11T10:17:00.671Z] Starting node.exe
[2019-01-11T10:17:04.846Z] info: [twx-studio:index] Studio Version 8.3.7.4156
[2019-01-11T10:17:04.852Z] error: [twx-studio:index] uncaughtException Error: HOME directory does not exist. Environment variable HOME=%HOMEDRIVE%%HOMEPATH% Fix the env variable and relaunch studio.
studio dir: %HOMEDRIVE%%HOMEPATH%\Documents\VuforiaStudio, home dir: %HOMEDRIVE%%HOMEPATH%\Documents
    at _verifyHomeDir (C:\Users\Venkatesh.a\AppData\Roaming\VuforiaStudio\studio-download.vuforia.io\dist\server\commonProperties.js:37:11)
    at Object.<anonymous> (C:\Users\Venkatesh.a\AppData\Roaming\VuforiaStudio\studio-download.vuforia.io\dist\server\commonProperties.js:40:1)
    at Module._compile (internal/modules/cjs/loader.js:688:30)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:699:10)
    at Module.load (internal/modules/cjs/loader.js:598:32)
    at tryModuleLoad (internal/modules/cjs/loader.js:537:12)
    at Function.Module._load (internal/modules/cjs/loader.js:529:3)
    at Module.require (internal/modules/cjs/loader.js:636:17)
    at require (internal/modules/cjs/helpers.js:20:18)
    at Object.<anonymous> (C:\Users\Venkatesh.a\AppData\Roaming\VuforiaStudio\studio-download.vuforia.io\dist\server\services\initializer.js:10:16) undefined
dupatel
(To:venkatesh)
@venkatesh Do you have external node application installed in your environment  as it causes conflict with Studio application. Also, it seems there could be issue with your environment variable values.
-Durgesh
venkatesh
2-Explorer
(To:dupatel)
Can you tell how to resolve it then.
