About the role assignment code in Expression
smcvr
wt.org.DirectoryContextProvider contextProvider = wt.inf.container.WTContainerHelper.service.getExchangeContainer().getContextProvider();
      wt.org.WTGroup wgroup = wt.org.OrganizationServicesHelper.manager.getGroup("YONETICI", contextProvider);
	 wt.query.QuerySpec qs = null;
      qs = new wt.query.QuerySpec(wt.org.WTGroup.class);
      wt.query.SearchCondition sc = new wt.query.SearchCondition(wt.org.WTGroup.class, wt.org.WTGroup.NAME, wt.query.SearchCondition.EQUAL, "YONETICI");
      qs.appendWhere(sc, new int[] { 0 });
  for(wt.fc.QueryResult queryResult = wt.fc.PersistenceHelper.manager.find(qs); queryResult != null && queryResult.hasMoreElements();)
     wgroup = (wt.org.WTGroup)queryResult.nextElement();
     java.util.ArrayList<WTUser> members = new java.util.ArrayList<WTUser>();
     java.util.Enumeration<wt.org.WTPrincipal> member = wgroup.members();
  while (member.hasMoreElements()) {
     wt.org.WTPrincipal principal = (wt.org.WTPrincipal) member.nextElement();
  if (principal instanceof WTUser){
     members.add((WTUser) principal);}
     wt.team.Team team = new wt.team.Team();
	 team.setName("My Team");
	 wt.org.WTPrincipal wtprincial = members.get(0);
        wt.project.Role role = wt.project.Role.toRole("Submitter");
      if (role == null) {
      team.addPrincipal(role, wtprincial);
      team.addPrincipal(wt.project.Role.toRole("Submitter"), wtprincial);
      wt.fc.PersistenceHelper.manager.save(team);
      team = (wt.team.Team)PersistenceHelper.manager.refresh(team);
The code above does not give an error, but when I run the flow, it does not return a user to me. There is a registered user in the "YONETICI" group, I want to assign that user to the Submitter role and send a task, but the task does not go to the user.
HelesicPetr
22-Sapphire I
(To:smcvr)
@smcvr
Additional information.
if you use a Variable to assign a participant do not use wt.project.Role. It can not work this way, Role as a object do not contains members it is just Enumeration. Use WTParticipant type or WTUser.
Also the variable can not be used as you use it with wt.team.TeamHelper.service.addRolePrincipalMap.
The assignee is a role from a team connected with primaryBusinessObject not with Variable of the task.
PetrH
15 REPLIES 15
HelesicPetr
22-Sapphire I
(To:smcvr)
Hi @smcvr
Show screen shot of workflow that others can imagine where the code and task are run
Check BacgroudnMethodServer.log if there is any error from WF
Last point the method Role.toRole("NAMEOFROLE") has to use internal name of the ROLE so Submitter I guess is SUBMITTER
PetrH
avillanueva
(To:smcvr)
Looks like you are creating a new team, not modifying the existing team of the workflow or PBO.  There is no tying the team you created to the workflow. Did I miss something?
smcvr
(To:avillanueva)
how can i add to existing team?
HelesicPetr
22-Sapphire I
(To:smcvr)
Hi @smcvr
Get the team from the object where the workflow is running on by following code
wt.team.Team team = wt.team.TeamHelper.service.getTeam(ci); // CI is a object Change Issue, WTPart, ChangeRequest, PromotionRequest what ever.
@avillanueva good point with the new Team I didn't check the code so carefully 😄
PetrH
smcvr
(To:HelesicPetr)
	 wt.query.QuerySpec qs = new wt.query.QuerySpec(wt.org.WTGroup.class);
     wt.workflow.work.WfAssignedActivity act = (wt.workflow.work.WfAssignedActivity) self.getObject();
	 wt.workflow.engine.WfProcess pro = (wt.workflow.engine.WfProcess) act.getParentProcess();
	 wt.team.Team team = wt.team.TeamHelper.service.getTeam(pro);
      if (role == null) {
I edited the code, I don't get an error in the expression, but when I run the workflow, it stops in the expression where the code is written and I get the following error
wt.util.WTException: java.lang.ClassCastException: wt.workflow.engine.WfProcess cannot be cast to wt.workflow.work.WfAssignedActivity
Nested exception is: java.lang.ClassCastException: wt.workflow.engine.WfProcess cannot be cast to wt.workflow.work.WfAssignedActivity
Nested exception is: wt.util.WTException: java.lang.ClassCastException: wt.workflow.engine.WfProcess cannot be cast to wt.workflow.work.WfAssignedActivity
wt.workflow.engine.FailedExpressionException: wt.util.WTException: java.lang.ClassCastException: wt.workflow.engine.WfProcess cannot be cast to wt.workflow.work.WfAssignedActivity
at wt.workflow.expr.WfExpression111135098.executemethod_1(WfExpression111135098.java:86)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at wt.workflow.definer.WfExpression.invokeByReflection(WfExpression.java:1465)
at wt.workflow.definer.WfExpression.executeTransition(WfExpression.java:1408)
at wt.workflow.definer.WfExpression.execute(WfExpression.java:477)
at wt.workflow.robots.WfExpressionRobot.run(WfExpressionRobot.java:162)
at wt.workflow.engine.StandardWfEngineService.runRobot(StandardWfEngineService.java:1187)
at sun.reflect.GeneratedMethodAccessor942.invoke(Unk
HelesicPetr
22-Sapphire I
(To:smcvr)
Hi @smcvr
The error tells you that object WfProcess can not be used in variable type WfAssignedActivity
So you need to work correctly with WFProcess,
if the code is run by robot directly in workflow then self.getObject(); is the object type WfProcess
if the code is run from workflow activity then self.getObject(); is the object type WfAssignedActivity and you need to get the parent object that is WfProcess
PS: you need to get the team from primaryBussinessObject not from workflow.
PS2: for better imagination 😄 Show screen shot of workflow that others can imagine where the code and task are run
PetrH
smcvr
(To:HelesicPetr)
Workflow:
Open Process Manager:
Code:
     wt.org.WTGroup wgroup = wt.org.OrganizationServicesHelper.manager.getGroup(katilimci, contextProvider);
     wt.query.SearchCondition sc = new wt.query.SearchCondition(wt.org.WTGroup.class, wt.org.WTGroup.NAME, wt.query.SearchCondition.EQUAL, katilimci);
    wt.change2.ChangeIssue ci =( wt.change2.ChangeIssue)primaryBusinessObject;
      if (role == null) {
I got the variable "kilimci" as a string from another expression. I changed the code as you said, it does not show an error in the code. There is no error in open process manager, but when it comes to the activity, it shows as completed and does not send me a task.
HelesicPetr
22-Sapphire I
(To:smcvr)
Hi @smcvr
You should use refresh to the saved team so
team  = (wt.team.Team)wt.fc.PersistenceHelper.manager.save(team);
I would check an task action if the role submitter is used in the task.
I guess there can be different role.
Also check the Member Participant list in a detail page of the primary object at a process tab
PetrH
Hi @smcvr
I checked my examples of the assigning the participants to roles so, try it
wt.org.WTPrincipal principal = ((wt.org.WTPrincipalReference)principals.nextElement()).getPrincipal();
wt.team.TeamHelper.service.addRolePrincipalMap(wt.project.Role.toRole("ASSIGNEE"), principal, teamActivity);
PetrH
smcvr
(To:HelesicPetr)
I did not understand what you said. there is no error in my code but it doesn't work. Thanks for be interested.
HelesicPetr
22-Sapphire I
(To:smcvr)
Hi @smcvr
I asked you to check if your role has been updated by your participant.
I'm trying to go step by step to show you why it does not work.
Additionally I said that you should use different function to set the participant to a role
So try it.
PetrH
smcvr
(To:HelesicPetr)
      role = wt.project.Role.toRole("ASSIGNEE");
The above part works. I pull the user from the group and assign it to the wtprincial variable but I can't pass it to the role variable
  if (role == null) {
	  wt.team.TeamHelper.service.addRolePrincipalMap(wt.project.Role.toRole("ASSIGNEE"), wtprincial, team);
HelesicPetr
22-Sapphire I
(To:smcvr)
Hi @smcvr
Do not use a Variable use a Role
What does condition if (role == null) means? if role exists it is never null.
PetrH
HelesicPetr
22-Sapphire I
(To:smcvr)
@smcvr
PetrH
smcvr
(To:HelesicPetr)
Hi @HelesicPetr ;
Thank you for the help. Workflow is running.
