Version: Windchill 13.0
Use Case: I am trying to include information within the context of a part instance that tells users where the part instances are allocated. But, I only want to show the parent part instances which the child is allocated to which are at a state of "Released". For example, I have part instance A which is a child of part instance B. Part instance B is at a state of "Released" at revision C. When I create a new revision of part instance B, the first iteration of revision D includes part instance A as a child within its structure. I can then remove part instance A from the structure of part instance B, revision D before setting the state of part instance B, revision D to "Released". If I then navigate to part instance A and look under the "Allocations" tab, part instance A is still said to be allocated to revision D of part instance B, despite part instance A not featuring in the structure of the released iteration of revision D of part instance B.
Description:
Is it possible to customize an information page to show all occurrences where my child part instance features in a "Released" parent instance?
Hi @Turko
The point is that the HELLO points to the previous iteration of D revision so it points to the D.1 but the releasing version is D.2 where the HELLO part is not included.
So this is how the system works.
PetrH
can you add some screenshots
Hi @Turko
PetrH
