Auto-collect affected/resulting object in change task.
DKWc
Hi All,
Trying to check the feasibility to auto-collect the affected/resulting object in the change task.
This would reduce the efforts of users to manually select each related doc, epm doc, etc.
Basically, the related objects of the WTPart should get collected.
Any suggestions/guidance appreciated.
Thanks in advance.
Durga
HelesicPetr
(To:DKWc)
Hi @DKWc
Yes, I have a suggestion
Go to the preference management-> change management and play with the Collectors options for affected / resulting tables
Based on the options in the preference management, a function collect objects will collect all what you would need.
PS> not perfect but it works.
PetrH
DKWc
(To:HelesicPetr)
Hi Petr,
Thanks for reply.
Tried out the recommendation, however it dosen't gets collected in affected object but gets in collection.
Any suggestions to get it populated in affected objects.
HelesicPetr
(To:DKWc)
Yes, It works that way.
PetrH
