Hi Shreyas,
Reference Topic - https://community.ptc.com/t5/Windchill/Check-for-Checked-Out-objects-in-the-Affected-Data-section-on-a/m-p/118248#M13997
Do you have a similar example for release target rule?
I am looking to setup Release Target rule in a Change Notice workflow similar to Checkout Rule you shared in the above post.
Hi @PJ_9888086
You can try to change the "wt.change2.RelevantRequestData" to a "wt.change2.ChangeRecord2"
CS63595 - Understanding Change Management objects and their relations
PetrH
