I wanted to add an validator for the resulting objects table, If release target is empty it should throw an warning to the user.
For this scenario I tried extending AffectedAndResultingItemsFormDelegate and ChangeTaskResultingItemsFormDelegate and overriding it's methods to just print dummy statements, it doesn't work for both delegates.
Thanks in advance
Hi @NA_9987879,
Thank you for your question.
Vivek N.
Community Moderation Team.
Hi @NA_9987879
I would ask if you set the settings what Delegate should be used in a config file custom-actions.xml
There is a action affectedAndResultingItemsStep
PetrH
