How to create a table with standard settings?
VladiSlav
Hello everyone, please tell me, I can form a standard settings table that will be displayed on the site page?
In the documentation I found an interesting example https://support.ptc.com/help/windchill/wc111_hc/whc_en/index.html#page/Windchill_Help_Center/WCCG_BusLogicCust_ChangeMgmt_FlexChangeLinks_WCCG_ChangeMgmt_FlexChangeLink_Procedure.html , but it is intended for building reports, is there such a way for ordinary tables?
6 REPLIES 6
ShirishMorkhadeI don't know much java yet, so I don't understand how to implement code examples yet. I would like to know if it is possible to create a table with standard settings from the site itself?
Well, you can reuse the already existing table from Windchill, but with very little extensibility. But to create brand new table, you need to have Windchill customization exposure.
- Shirish
ShirishMorkhade,  сan I add a table "Promotion Object" to the "Task" page so that I don't have to switch between pages when checking?
@VladiSlav , to my knowledge yes, you can achieve this. Try exploring native task from templates.
Best Regards,
Shirish
ShirishMorkhade, need to create a new template or add actions to an existing one?
I tried following the example to add code, but I was having trouble https://community.ptc.com/t5/Windchill/What-type-should-be-the-variable-obj/td-p/633150
