I browsed xml file from tasks folder I want to execute it. But it is asking for inputs like supporting adapter and object for an Create.xml file. what are these and how to execute the file..??
You need to provide a VM/adapter name in your task. The best method is to get the value of wt.federation.ie.VMName from wt.property. It is something like reverse of your server name with a .Windchill appended to it.
String instance = wt.util.WTProperties.getLocalProperties().getProperty("wt.federation.ie.VMName");
<ie:webject name="Query-Objects" type="OBJ">
<ie:param name="instance" data="<%=instance%>"/>
<ie:param name="WHERE" data="name='$(@FORM[]name[])'" default=""/>
<ie:param name="TYPE" data="wt.maturity.PromotionNotice"/>
<ie:param name="ATTRIBUTE" data="*" delim=","/>
<ie:param name="GROUP_OUT" data="PromotionNotice"/>
</ie:webject>
