How to hold View value to "Design" in part creation
LeoWNC
3-Newcomer
Dear all,
I'm trying to hold "design" selection for attribute "View" during the creation of a part in Windchill 10.1 v M040. There are two views, Design and Manufacturing.
View attribute does't support default option. If I remove the attribute from the "Create New Layout", its value is unassigned; and it's can't be accetped.
I followed this article:
https://www.ptc.com/en/support/article/CS286220?
but it does't work. Probably there is something in system configuration that collides with the provided solution .
Do You have any suggestions?
Tnx
2 REPLIES 2
jvonzastrow1
(To:LeoWNC)
You can set the default view with preference "Default Part View"
MichaelChatel
20-Turquoise
(To:LeoWNC)
Hi, to add to jvonzastrow1's response, check out this knowledge article, we have on this:
https://www.ptc.com/en/support/article/CS30181
As he mentioned, Default Part View.
If you have trouble with this, I'd suggest opening a Support case, to help you walk through it.
Mike
