Dear all,
I'm trying to hold "design" selection for attribute "View" during the creation of a part in Windchill 10.1 v M040. There are two views, Design and Manufacturing.
View attribute does't support default option. If I remove the attribute from the "Create New Layout", its value is unassigned; and it's can't be accetped.
I followed this article:
https://www.ptc.com/en/support/article/CS286220?
but it does't work. Probably there is something in system configuration that collides with the provided solution .
Do You have any suggestions?
Tnx
You can set the default view with preference "Default Part View"
Hi, to add to jvonzastrow1's response, check out this knowledge article, we have on this:
https://www.ptc.com/en/support/article/CS30181
As he mentioned, Default Part View.
If you have trouble with this, I'd suggest opening a Support case, to help you walk through it.
Mike
