When performing a Save As in PTC Windchill I am easily able to add hot link locations when I want to set a location. However I cannot find out how to remove hot links that I have added and no longer need to use. Do anyone know how to do this?
Hi @arthomas,
Can you navigate to Quick Links(menu on right hand top corner)-> My notebook and check under "My hot Links" if you see the object links there.
Bhushan
Hi @arthomas,
Bhushan
Thank you so much!!! I am able to remove hot links from the area that you specified.
