QuerySpec to get latest version of all alternate BOM created in windchill
PD_2014
Version: Windchill 12.0
Use Case: I want to get all the latest version of manufacturing alternate BOM created in windchill.Please find the attachment for the output requirement.
Description:
Hello @PD_2014
Thank you for your question.
Your question appears to be well documented, however I'd like to recommend to bring more details and context to your initial inquiry.
Thanks & Regards,
Community Moderation Team.
Marcika
(To:PD_2014)
The "General View" shows all version of a part. To show only the latest versions from a view you can create a new view (called "Alternate Latest") which can be exactly the same as "General" view with the exception that you should add some filters in plus at step "Set Filters":
Result:
Created filter can be exported and reimported during build if needed.
