Simplified Reps & Creo View
mszwabowski
When Creo View publishes an assembly, it publishes the Master Rep.  Is there a way to have Creo View publish the Default Rep instead?
If not, is there a way to enable access to Simplified Reps in Creo View?
In the recipe editor go to Parameters > Author States
select "Simplified Reps"
I also have everything else selected on this tab also.
