Uncheck existing downstream objects in Add Object wizard in BOM Transformer
Sha11
When we do a drag and drop of upstream child component to downstream view, when there are multiple downstream objects, in Add Object wizard all the applicable objects will be displayed. My requirement is when the Add Object wizard is launched, by default all objects should be unchecked. Updating the preference Paste as New Part or Paste as New Branch is not an option, requesting you to shed some light on the same.
Sha
1 REPLY 1
Fadel
23-Emerald I
(To:Sha11)
The BOM Transformer is based on GWT and its not open for custo ,just limited stuff on ribbon https://www.ptc.com/en/support/article/cs165341
Fede
