Is there a way to update a PDF in a CAD document with a PDF in a drawing using a REST API in Windchill? If so, which API should I use? Could you provide me with information on this?
As an example, how can I update the PDF indicated in the image?
Hi @ozclkonur,
Thank you for your question.
I am replying to raise awareness. Hopefully, another community member will be able to help.
Meanwhile, if possible I’d like to recommend to bring more details to your initial inquiry.
Vivek N
Community Moderation Team.
