Getting attribute on WTpart from WTpartUsageLink in a BuisnessAlgorithm
JM_12529808
Version: Windchill 12.1
Use Case: Comparing values between an WTpart attribute and a WTpartUsageLink attribute, in a BuisnessAlgorithm - to use on a calculated value on WTpartUsageLink.
Description:
Following this procedure: Procedure – Using a BusinessAlgorithm in a Calculated Attribute togehter with this knowledge base: New java algorithm for calculated attributes (BusinessAlgorithm) starting Windchill 11.0
We have a calculated value on a WTpartUsageLink. This should compare an attribute from the WTpartUsageLink and the WTpart that it is linked to. The attribute from the WTpartUsageLink can be passed as a variable in the execute statement, but I have a hard time referencing the attribute from the WTpart.
Sample code or a pointer for referencing an attribute in this use case would be very helpfull.
Fadel
23-Emerald I
(To:JM_12529808)
How about using alias attributes mapping to get the info between parts and usagelinks
https://www.ptc.com/en/support/article/CS245103
Fede
JM_12529808
(To:Fadel)
Hi Fadel
Thanks for the suggestion - Alias have the very annoying caveat that it will fetch info for all iterations of a part, and not just the iteration that is currently chosen in the Config Spec, so it wont work for this specific use case.
Hello @JM_12529808,
It looks like you have a response from a community expert. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
