com.ptc.wpcfg.pdmabstr in Windchill 13.1.2.0
RR_10870535
3-Newcomer
I am using Windchill PDMLink Release 13.1 and Datecode with CPS 13.1.2.0
During an update from Windchill 12.0 to Windchill 13.1.2 I had an issue with compiling a java file.
import com.ptc.wpcfg.pdmabstr.PROEDependency; is used in the file but it's not recognised by Eclips.
The class should be availeble in DDLBasic.jar. Is it moved or deleted (com.ptc.wpcfg.pdmabstr)? Do I neet to use something different?
I have a workaround, the variable is used once and should be a constant value, but that is not a clean solution.
3 REPLIES 3
Fadel
23-Emerald I
(To:RR_10870535)
can you run below command on the 12 and 13 system
windchill wt.util.jmx.Which com/ptc/wpcfg/pdmabstr/PROEDependency.class
Fede
RR_10870535
3-Newcomer
(To:Fadel)
Hello Fede,
Thank you for your response.
On the new server Windchill 12.1 and 13.2 is installed.
I tryed your action in the Windchill shell for both versions.
At windchill 12.1 the resource is found:
At Windchill 13 the resource is not found:
Hi @RR_10870535,
Anurag
