can you run below command on the 12 and 13 system
windchill wt.util.jmx.Which com/ptc/wpcfg/pdmabstr/PROEDependency.class
Hello Fede,
Thank you for your response.
On the new server Windchill 12.1 and 13.2 is installed.
I tryed your action in the Windchill shell for both versions.
At windchill 12.1 the resource is found:
At Windchill 13 the resource is not found:
Hi @RR_10870535,
Anurag
