how to get a date as today in query builder?
pmanwal
Creating a report in report management to find all object modified today and then schedule it to run on daily basis. Tried with system date function but not giving correct result.
4 REPLIES 4
BineshKumar1
(To:pmanwal)
The sysdate function will return the date based on the database's operating system. when you say incorrect result, how incorrect are they?
pmanwal
(To:BineshKumar1)
i need to schedule this report using Data Monitor. Want to execute report daily at specific time. when i used system date function, it gives me 0 results. whereas there are object modified on that Date.
I think this is the format in which it returns the value as include the time as well.
BineshKumar1
(To:pmanwal)
Did you add the criteria like this?
pmanwal
(To:BineshKumar1)
Hey Binesh, Thanks  a  lot. Didn't realize the way you have done it. Just 1 more favor if you just explain how does it work.
Thanks again
