i want to customize the workflow activity task jsp page
RaikarRaghu
I created the attribute called customer name inside the WTDocument. the value of the attribute should be updated once the activity get completed.
i wanted to add the dropdown list inside the workflow activity task page, It contains some customer names like A, B C, D based on the selection of the user from the dropdown list it should be persist into the customer name attribute.
please help me to solve this. if some have any code snippet please share.
HelesicPetr
(To:RaikarRaghu)
Hi @RaikarRaghu
So you have done something wrong.
It works.
for example if you forgot set the properties by windchill shell and forgot to use the propagation
xconfmanager -s wt.workflow.definer.variable.ShowWfEvolvableWarning=true -t codebase/wt.properties -p
PetrH
6 REPLIES 6
HelesicPetr
(To:RaikarRaghu)
Hello ,
I wanted the dropdown as i mentioned in the given below image. I gone through the suggested article dropdown is not coming.
HelesicPetr
(To:RaikarRaghu)
Hi @RaikarRaghu
It works.
PetrH
I run this property after i took restart and i created a new workflow i add my class name with package in otherclass, it is not allowing to complete.
HelesicPetr
(To:RaikarRaghu)
Hi @RaikarRaghu
The reason could be that your class does not exist or is not well defined or you miss some compilation of rbinfo.
Who knows I don't know what you did. .
In the Default value you should see the list of values. If it is not there, then you have done something wrong,
PetrH
Hi @RaikarRaghu,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina
Community Moderator
Catalina
PTC Community Moderator
PTC
