I need to check the CN summary of over 200 CNs. Is it possible to pull multiple CN summary at once or is there any customization possible for this.
Thanks!!
I believe you would have to create a report for it. That would be the only way I know of.
The org and site admins have access to the Utilities. There is an area there called Report Management. It can be very tricky to create them but there is a post on this forum for all sorts of reports.
https://community.ptc.com/t5/Windchill-Tips/Resource-for-reporting/m-p/448738#M208
Hello @venkatraj
If the above posts resolves your issue or answers your question, please mark it as an Accepted Solution. This will help ensure other community members with the same question can quickly find an answer.
Thank you both for your contributions to the PTC community!
PTCModerator
