I want to display 3D model in Creoview or Thingview, but as I bind 3D model to that widgets it's shows nothing.
please find attached img for linking ref.
Hi @Swapnil_More ,
you can check now to AR> Tech Tips(https://community.ptc.com/t5/Studio-Tech-Tips/bd-p/studiotips) -> main article is:
Hi @Swapnil_More ,
so as shown in you picture you tried to display the model in 2 different views: Creo view and thingview.
For creo View - if you try to display you mashup in chrome - it will definitely not work. It work only on windows explorer where activeX are allowed. So that I do not think, that this is a real opton for usage.
So the second view thingview should work for pvz models.
Here example (in pictures):
Here example for sequence and selection on element tree (requires boom see Tech Tip on AR Studio community😞
Also animations are working too.
Because it is not trivial to get this working , and could not be explained with few words , so I will not mention further details in this post.
I am plaining to write a tech tip soon in the AR Studio community - hope until end of the next week.
Thank you & awaiting for your valueable tech-tips.
Hi @Swapnil_More ,
