Is thingworx navigate integration with Flex PLM possible?
If yes, which are the connectors or utilities to be used for integrating?
Thanks in advance.
Kiran Gurav
Hi Kiran,
Currently, there are no app in Thingworx Navigate to view Flex objects.
However, there's Thingworx - Tech Pack Connect App which provides the ability to access specification artifacts from PTC Windchill FlexPLM.
More information available at Tech Pack Help Center
You can also build Dashboard Definition using Thingworx mashup, refer Creating Dashboard Definition
Arshad
Hi Kiran,
Arshad
