All,
I am trying to run the PSI to install a file server on a Windows Server 2008 box. I am at the screen where I specify the HTTP port number (default is 80) and I get an error that it is unable to bind to HTTP port specified. IIS is not installed and when I run a netstat -a there is nothing running on port 80. Does anyone have any experience installing on 2008?
Patrick Williams | Engineering Systems | Sr. Applications Engineer | Steelcase Inc. | 616.698.4078
[cid:image001.jpg@01CA4C18.CD106410]
