AE Control Characteristic Designate to Process Plan Use
bwudtke
I am looking to publishing a stand alone AE floating note from creo  to windchill control characteristics on a W2 part.  This will allow the notes to be published to MCAD to be used in a process plan step.  I have gotten this note to show up in Creo view as a floating note but doesn't show in the control characteristics tab on the process plan. Is there a specific windchill setting that needs to be set to allow any control characteristic to be used downstream?
All GD&T shows on the process plan steps but not the floating note.
See Figure 1 for creation of control characteristic in Creo.
See figure 2 attached for view when selecting AE floating note in creo view.  Again,  this is seen in creo view, but not process plan step.
0 REPLIES 0
