I'm trying to access my Windchill on my network, this server is not in the domain, plus ping on its normal IP do I need to release something else for internal access? Today I'm using http.
Hi @MS_Santos
If the system is not in domain you need to use host file where you define the server address and IP address
also check firewall
PetrH
Hi @MS_Santos
also check firewall
PetrH
I got it thanks for the help
