Adding Attribute to Visualization and attribute/General/System area
NSS
Is it possible to add  "Attribute" to Visualization and attribute/General/System area through configuration? (May be possible through coding, I want to confirm will be made it via configuration)
Thanks!
HelesicPetr
(To:NSS)
@NSS
Yes you can.
Type&Attribute management is the right place.
For each subtype you can define specific layout with attributes what you need
PetrH
HelesicPetr
(To:NSS)
@NSS
Yes you can.
PetrH
NSS
(To:HelesicPetr)
Thank you,  got it.
