I am planning to export an complete assembly from windchill to my local Drive. During export of the assembly there are few missing part files. Need help on it.
Just so you know, this is the Community site, where PTC users help each other with questions. This isn't direct support from PTC.
Regarding your issue, have you checked that you have access to the parts? If the parts are stored in different Products, you may not have access to all of them. This would cause the issue you're seeing. You can check by searching for one of the missing part numbers in Windchill, and see if it returns results. If you don't have the proper access, it would be something your company's Windchill administrator should be able to help with.
I am seeking help on the issue raised , can any one support me.
Warning: 427-00307_PRESSURE PLUG, MONACO.prt - Failed to find file using current search options, part left unloaded
Warning: 436-00293, FOAM, GRILLE TO BAFFKET SIDES, MONACO.prt - Failed to find file using current search options, part left unloaded
Warning: 438-00263, GASKET, MESH STACK ASSY, MONACO, FULLY-MTS.prt - Failed to find file using current search options, part left unloaded
Warning: 438-00262, GASKET, MESH STACK ASSY, MONACO, SEMI-OTS.prt - Failed to find file using current search options, part left unloaded
Warning: 410-00226, PSA, GRILLE SUBSTRATE TO BAFFKET, CENTER, MONACO.prt - Failed to find file using current search options, part left unloaded
Warning: 440-00412.prt - Failed to find file using current search options, part left unloaded
Warning: 436-00272, LIGHT BLOCKER FOAM, BATTERY, MONACO.prt - Failed to find file using current search options, part left unloaded
Warning: 436-00271, LIGHT BLOCKER FOAM RING, GRILLE SUBASSY, MONACO.prt - Failed to find file using current search options, part left unloaded
Warning: 410-00191, HAF, GRILLE SUBASSY, MONACO.prt - Failed to find file using current search options, part left unloaded
Warning: 930-005111, PCBA, Monaco CPU-RF-SL.prt - Failed to find file using current search options, part left unloaded
Warning: 410-00235, KAPTON TAPE, PWR-AMP EMI SHIELD, MONACO.prt - Failed to find file using current search options, part left unloaded
Warning: monaco_rx_coil_asm_0825.prt - Failed to find file using current search options, part left unloaded
Warning: monaco_rx_coil_asm_0821 (1).prt - Failed to find file using current search options, part left unloaded
Warning: 170-01452_20200902-SL.prt - Failed to find file using current search options, part left unloaded
Warning: 170-001436_20200814_removed.prt - Failed to find file using current search options, part left unloaded
Warning: 170-01452_20200902.prt - Failed to find file using current search options, part left unloaded
Warning: 170-01436_20200714.prt - Failed to find file using current search options, part left unloaded
Warning: 170-001396_20200413.prt - Failed to find file using current search options, part left unloaded
Warning: 170-001396_20200331.prt - Failed to find file using current search options, part left unloaded
Warning: 170-001396_20200326.prt - Failed to find file using current search options, part left unloaded
Warning: 170-01340_051219.prt - Failed to find file using current search options, part left unloaded
Warning: 170-01530_20200129.prt - Failed to find file using current search options, part left unloaded
Warning: 170-01495_20210105.prt - Failed to find file using current search options, part left unloaded
Warning: 170-01495_20210104.prt - Failed to find file using current search options, part left unloaded
Warning: 170-01495_20201105.prt - Failed to find file using current search options, part left unloaded
Warning: 170-01449_20200928.prt - Failed to find file using current search options, part left unloaded
Warning: 170-01449_20200908.prt - Failed to find file using current search options, part left unloaded
Warning: 170-01447_070820.prt - Failed to find file using current search options, part left unloaded
Warning: 170-001443_20200728_2.prt - Failed to find file using current search options, part left unloaded
Warning: 170-01443_20200728.prt - Failed to find file using current search options, part left unloaded
Warning: 170-01443_20200724_2.prt - Failed to find file using current search options, part left unloaded
Warning: 170-01443_20200724.prt - Failed to find file using current search options, part left unloaded
Warning: inductor shield - two piece.prt - Failed to find file using current search options, part left unloaded
Warning: 170-01435_20200709.prt - Failed to find file using current search options, part left unloaded
Warning: inductor shield.prt - Failed to find file using current search options, part left unloaded
Warning: 170-01435_20200708_1.prt - Failed to find file using current search options, part left unloaded
Warning: 170-01394_100420.prt - Failed to find file using current search options, part left unloaded
Warning: 170-01394_090420.prt - Failed to find file using current search options, part left unloaded
Warning: 170-01316_091219.prt - Failed to find file using current search options, part left unloaded
Warning: 170-01316_061219-rev3.prt - Failed to find file using current search options, part left unloaded
Warning: 170-01457_20200903.prt - Failed to find file using current search options, part left unloaded
Warning: 170-01433_20200725.prt - Failed to find file using current search options, part left unloaded
Warning: 170-001433_20200714.prt - Failed to find file using current search options, part left unloaded
Warning: 170-001425_20200515.prt - Failed to find file using current search options, part left unloaded
Warning: 170-001388_20200410.prt - Failed to find file using current search options, part left unloaded
Warning: 170-001388_20200331_2.prt - Failed to find file using current search options, part left unloaded
Warning: 170-001388_20200331.prt - Failed to find file using current search options, part left unloaded
Warning: 170-001388_20200320.prt - Failed to find file using current search options, part left unloaded
Warning: 170-001315_20191209.prt - Failed to find file using current search options, part left unloaded
Warning: CC0603.prt - Failed to find file using current search options, part left unloaded
Warning: 170-01434, PCB, MONACO CPU-RF-SL, R0.prt - Failed to find file using current search options
Hi @SD_10735412
Do you use export from workspace?
if so, you should use add to workspace with basic collator and with all dependencies.
Then try to export and open in NX
PetrH
