Build action issue
Sandy7
11-Garnet
Build action issue
i am facing one problem while performing build action. the corresponding gear parts are not showing up even they are associated with CAD. see attachment.
creo-7
windchill-12
please help.
thanks,
sandy
avillanueva
(To:Sandy7)
https://www.ptc.com/en/support/article/CS260882?source=search
Looks like the CAD is linked to multiple versions? I think you need to remove the CAD association from the A version. Make sure you revise both together. You can do this in a clean empty workspace against the older version. Might need admin if released.
6 REPLIES 6
HelesicPetr
22-Sapphire I
(To:Sandy7)
Hi @Sandy7
Why do you not use owner association?
What error is shown on the red sign in the middle of a comparation table.
PetrH
error is "The CAD document has owner association to multiple parts and the system cannot resolvewhich one to add. the actions to build part structure will fail."
HelesicPetr
22-Sapphire I
(To:Sandy7)
Hi @Sandy7
The error says everything.
So you need to chose the correct WTpart that should be build 😄
But in your case you do not have a right to see that WTPart.
You need to contact administrator to solve the issue that you can see the wtparts that are associated to the CAD Model.
PetrH
avillanueva
(To:Sandy7)
Hi @avillanueva and all, thanks for the help. as the parts were released, Admin  helped me to update association. the build is good now.
Br,
Sandeep C.
Hi
Can you try this
1.Clear the workspace first
2. Second download(add to workspace) the error parts (least part ) in workspace
3. then download (add to workspace) the assembly files then it will work
or
otherwise you need to build properly in BOM structure
Sarathkumar M
