Bulk Item Unit issue
Aaronm87
Version: Windchill 12.1
Use Case: Bulk item listed as feet in Creo, but is converted to meters in Windchill
Description:
I've tried looking but I cant seem to find how to change this. If I have a bulk item with quantity parameter listed in feet, the WT Part structure defaults to meters.
For example, if I have 20 feet listed for the bulk item, the part structure will show the part as requiring 6.7 meters.
BenLoosli
(To:Aaronm87)
Check in Type and Attribute manager for the units of your attribute. They may be set to meters in Windchill.
Aaronm87
(To:BenLoosli)
I checked. It shows USCS as the preference.
Hello @Aaronm87
It looks like you have a response on your topic. If it helped to answer your question please mark the reply as the Accepted Solution. If you were able to find a solution yourselves, please reply to this topic and mark it as accepted solution. This will surely help other users who may have a similar question.
Vivek N.
Community Moderation Team.
