We have this issue with CAD represented parts which do not have representation, is there anyway, out of a full vehicle BOM, to determine which parts are missing representations so we can set about fixing them?
I think when I encountered an error like this, I would just republish the topmost assembly and all items under it. But perhaps you are wanting to avoid that, I'm not certain.
James
I had a solution from Robbie Morrison at PTC, in summary, CAD represented parts without representation will have an attribute 'no_representation' = True, so you can search on this in Creo View or in Structure tab if the attribute has been made visible. In our case when searching in WT structures our WT assemblies all showed as having 'no_representation' = True because they were just structure, so it was necessary to use a multi-line search in Creo View for the Existence of both 'no_representation' and 'CAD_represented_part'
