Try looking at CORS filter in Windchill\tomcat\conf\web.xml
<filter>
<filter-name>CorsFilter</filter-name>
<filter-class>org.apache.catalina.filters.CorsFilter</filter-class>
<init-param>
<param-name>cors.allowed.origins</param-name>
<param-value>null</param-value>
</init-param>
<init-param>
<param-name>cors.allowed.methods</param-name>
<param-value>GET,POST,HEAD,OPTIONS,PUT</param-value>
</init-param>
<init-param>
<param-name>cors.allowed.headers</param-name>
<param-value>Content-Type,X-Requested-With,accept,Origin,Access-Control-Request-Method,Access-Control-Request-Headers</param-value>
</init-param>
<init-param>
<param-name>cors.exposed.headers</param-name>
<param-value>Access-Control-Allow-Origin,Access-Control-Allow-Credentials</param-value>
</init-param>
<init-param>
<param-name>cors.support.credentials</param-name>
<param-value>true</param-value>
</init-param>
<init-param>
<param-name>cors.preflight.maxage</param-name>
<param-value>10</param-value>
</init-param>
</filter>
<filter-mapping>
<url-pattern>/*</url-pattern>
</filter-mapping>
Kind regards,
Dmitry
Thanks for your response.
Is the CORS exception need to be enabled in the Windchill\tomcat\conf\web.xml or the Windchilll\codebase\WEB-INF\web.xml
Hello amarjit,
Can you review kb article https://www.ptc.com/en/support/article/CS378185 ?
KR,
Charles.
Hello amarjit,
Were the information provided helpful somehow ?
KR,
Charles.
Windchill help file suggest editing <Windchill_Home>\codebase\WEB-INF\web.xml
As for me, I've struggled a lot a few years ago and managed to make it work by editing tomcat configuration directly and I'm certainly won't touch anything now unless it breaks 😃
Hi, I also struggled long with the cors topic. Until I finally found the problem.
<filter-name>ContentCorsFilter</filter-name>
<init-param>
<param-value>http://localhost:4200</param-value>
</init-param>
<init-param>
</init-param>
<init-param>
<param-value>GET,POST,OPTIONS</param-value>
</init-param>
<init-param>
<param-value>Content-Type,X-Requested-With,Access-Control-Allow-Origin,Access-Control-Allow-Credentials</param-value>
</init-param>
</filter>
<filter>
<filter-name>ContentHttpHeaderSecurityFilter</filter-name>
<filter-class>org.apache.catalina.filters.HttpHeaderSecurityFilter</filter-class>
<init-param>
<param-name>antiClickJackingOption</param-name>
<param-value>ALLOW-FROM</param-value>
</init-param>
<init-param>
<param-name>antiClickJackingUri</param-name>
</init-param>
</filter>
<filter-mapping>
<url-pattern>/servlet/WindchillAuthGW/wt.content.ContentHttp/viewContent/*</url-pattern>
<url-pattern>/servlet/WindchillGW/wt.fv.master.StandardMasterService/doDirectDownload/*</url-pattern>
<url-pattern>/servlet/WindchillGW/wt.fv.replica.StandardReplicaService/doDownload/*</url-pattern>
<url-pattern>/servlet/WindchillGW/wt.fv.replica.StandardReplicaService/doIndirectDownLoad/*</url-pattern>
<url-pattern>/servlet/WindchillGW/wt.fv.uploadtocache.DoUploadToCache_Server/doUploadToCache_Master</url-pattern>
<url-pattern>/servlet/WindchillGW/wt.fv.uploadtocache.DoUploadToCache_Server/doUploadToCache_Replica</url-pattern>
</filter-mapping>
<filter-mapping>
</filter-mapping>
My problem was, that the tag cors.allowed.headers did not have the appropriate header information in it. This is just missing in the WNC help.
Adding the above entries to the codebase/WEB-INF/web.xml solved all my CORS problems.
