Hi @RS_10128209
Maybe you use wrong type.
it is hard to say if you do not provide full log error.
PetrH
I think that, in order to get a response from some experienced users in the community, this request needs to be much more detailed.
The way it is worded it is too general.
Hi @RS_10128209
A general question can be answered just with general answer.
1. Plan what data are migrated
2. Create MAP of your data in a old system and in a new system
3 Define what information should be migrated based on the map
4. Define a way how the information are migrated
5 Find or crate tool for migration
6 Test the migration on just small amount data
7 Test full migration
9 identify the problem data
10 solve problem data
11 plan the production migration.
I may forget some steps but generally this is good start
PetrH
Hi @HelesicPetr Thanks for the reply.
I have performed all steps and loaded wtdocument into target but while loading Content of wtdocument using its throwing me a error query
SELECT staging.sequencenumber AS SEQUENCENUMBER ,staging.type AS CLASS FROM CONTENTMETADATA staging, CONTENTMETADATAWBMStatus st WHERE staging.migrated =0 AND staging.sequencenumber = st.sequencenumber AND st.POSTVERIFICATIONSTATUS IS NULL AND st.loadstatus = 'STARTED';
Everything is right but as its trying to fetch sequencenumber and type from CONTENTMETADATA and CONTENTMETADATAWBMStatus, Type is not available in CONTENTMETADATAWBMStatus then how it will pass the query?
Hi @RS_10128209
PetrH
I have used type in contentmetadata as 'wt.content.ApplicationData'
