I have a brand new install of PDMLink 13 and noticed in my testing that both Change Request and Problem Report are missing from actions. I am still in the middle of configuring things so I have applied my customizations from 12 and brought in my lifecycles, workflows and OIRs. I do see Change Notice and Promotion Request. Scratching head here but I am sure its something simple.
I do have some additional actions like Delete Representations that I added in. I checked the licenses and the user I am testing does have Windchill Advanced license among others. What's weird is that if I look at jcaDebug, its not even greyed out.
Why is it with out fail, 5 mins after I post something, the solution appears before me? I used to work in a college bookstore and as soon as I told a student I could not find a book, I would find it while helping the next student. Ok, time for some appropriate memes:
So I was double checking my snapshots and noticed this around one of the core files I was restoring...
Yeah, fat fingered the copy and the actionModel and actions file were identical. Lesson for all as soon as you complete install, take a backup or have snapshots running. File restore, all is well. Good thing I like eggs.
Could you please verify if the actionmodel namded folderbrowser_toolbar_new_submenu is in Windchill/codebase/config/actions/custom-actionModels.xml?
If there is, please compare the actionModel definition with OOTB one which is defined in Windchill/codebase/config/actions/FolderManagement-actionModels.xml.
The following two actions should be in the model with name folderbrowser_toolbar_new_submenu, like below:
<model name="folderbrowser_toolbar_new_submenu" resourceBundle="com.ptc.windchill.enterprise.folder.FolderActionResource">
</model>
"It's me, hi, I'm the problem, it's me". Yep, I sure its something I did. I am checking my custom action model files which I tried cleaning up but may have introduced a bug.
actionmodels.xml file is missing an entry called action search table toolbar. Please add the model and restart the server.
I saw this message on screen when digging into jcaDebug so yep, @Maggie_Ma , you are on the right track.
Perhaps I spoke too soon. There seems to be a more fundamental issue. I have reset custom-actions.xml and custom-actionModels.xml back to original (empty) and verified that all the OOTB actions and actionModels in the config/actions folder is OOTB (dated 6/25/2024) to 13.0.2 CPS 4. I cleared tomcat cache, cleared compiledTasks and ran MakeJar. I hope that is all I need to do to clear things. Upon restart, things look ok but UI quickly starts throwing weird messages like below that I do not understand. So my initial title of post might be off. Here is what I am seeing in logs:
(com.ptc.netmarkets.util.misc.miscResource/400) com.ptc.netmarkets.model.NmException: actionmodels.xml file is missing an entry called product navigation. Please add the model and restart the server.
ctionmodels.xml file is missing an entry called clfAdmin navigation. Please add the model and restart the server.
com.ptc.netmarkets.model.NmException: actionmodels.xml file is missing an entry called action search table toolbar. Please add
java.lang.NoSuchMethodException: Unkno
wn property 'class' on class 'class com.ptc.core.components.factory.DefaultComponentDescriptor'
2025-03-19 13:24:20,763 ERROR [ajp-nio-127.0.0.1-8010-exec-4] com.ptc.carambola.CustomizationPage <user> - Did not find any instance of wt.change2.WTChangeIssue object. Some example
s will not work unless at least one wt.change2.WTChangeIssue object has been created.
2025-03-19 13:24:20,765 ERROR [ajp-nio-127.0.0.1-8010-exec-4] com.ptc.jca.error <user>- ---------- JCA Exception ---------- jakarta.servlet.jsp.JspException: wt.util.WTException: j
ava.lang.NullPointerException: Cannot invoke "com.ptc.netmarkets.util.misc.NmAction.isHidden()" because "this.action" is null
2025-03-19 13:24:09,739 ERROR [ajp-nio-127.0.0.1-8010-exec-8] com.ptc.netmarkets.util.misc.StandardNmActionService.general <user>- Action Name prevButton defined in config/actions/
ChangeManagement-actions.xml don't have expected parent element [objecttype]
2025-03-19 13:24:09,739 ERROR [ajp-nio-127.0.0.1-8010-exec-8] com.ptc.netmarkets.util.misc.StandardNmActionService.general <user> - wt.util.WTException: Action Name prevButton defin
ed in config/actions/ChangeManagement-actions.xml don't have expected parent element [objecttype] wt.util.WTException: Action Name prevButton defined in config/actions/ChangeManagement-a
Nested exception is: java.lang.NullPointerException: Cannot invoke "com.ptc.netmarkets.util.misc.NmAction.isHidden()" because "this.action" is null
The errors above are in no particular order, just snippet from Methodserver logs to jog any of you out there. When I started this, things seems ok for a new install. I started my configuration creating soft-types, creating attributes and applying customizations. Things were ok when imported workflows, lifecycles, OIRs, creating groups and contexts. As I mentioned, I saw some of my custom actions but then I noticed some OOTB things missing. As far as I know, what I seeing is not database related it is? when changes are made to actions and action models, do I have the proper steps to clear and rebuild setup? My next steps would be to try and unwind some of the customizations I've added. I can't imagine much dependencies on custom classes or other additions.
