Change default from Home->Overview to Home->Assignments in Windchill 9.1
ArronCochran
If I am in the Home->Assignments screen and click on a change task to complete it, Windchill will send me back to the Home->Overview screen. It seems monotonous to have to keep going back to the Home->Assignments table to be able to sort the information in order to go to the next task. Does anyone know of a way to have it return to the screen where I started?
Arron Cochran
I do not know how to do it with windchill, but as a workaround I usually use right-click/open in new tab. This way my assignment page remains available.
HTH,
Vincent Quesnoit
In Reply to Arron Cochran:
If I am in the Home->Assignments screen and click on a change task to complete it, Windchill will send me back to the Home->Overview screen. It seems monotonous to have to keep going back to the Home->Assignments table to be able to sort the information in order to go to the next task. Does anyone know of a way to have it return to the screen where I started? Thanks, Arron Cochran
This is a configuration option available via the actions XML file.
Documented in the customizer's guide PDF. It may require a stickiness
preference change. PTC Support should be able to provide help on this.
