Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
All symptoms of ajax server network latency..have noticed even in VMWare 9.1 MO30 has greater ajax latency then MO20 sounds like PTC R&D needs to investigate ...can give more input if needed
Raju, We have seen similar issues like disabling OK/Finish buttons while creating ECOs. We were never able to reproduce them consistently. Only workaround we suggest users is to close the pop up window and retry. We also ran into issue with clicking menu items for some users with IE browsers. We got the following suggestion from Tech support to change a browser related registry entry as follows on client machines
change value of *HKEY_CLASSES_ROOT\TypeLib\{**EAB22AC0-30C1-11CF-A7EB-**0000C05BAE0B}\1.1\0\win32 from C:\WINDOWS\system32\shdocvw.**dll to C:\WINDOWS\system32\ieframe.**dll*
This change not only fixed menu items issue with IE browser, it also fixed the same issue for Chrome browser. Now I am able to use Chrome for most of the Windchill UI and it is way faster than IE and FireFox.
