Copy and paste activities in project schedule - running project
Sathish_Rosario
We are unable to copy paste the activities in running project schedule.
Copy and paste available during project plan creation (Defined and scheduled state)
Copy and paste NOT available during project running (Running and Inprocess)
Since copy and paste feature is not available, we are creating existing activities repeatedly, when required.
Any work around and am I missing something?
Thank you
Sathish Rosario
Hi @Sathish_Rosario
If the process plan is in a process or executed and is autoexecuted you can edit the plan if it is paused (suspended).
PetrH
Are you using Manual Execution or Automatic Execution? There are specific differences between the two and it sounds like you should move to Manual Execution if you are not executing a static process.
Check out the Execution of Plans topic in the Windchill Help Center.
https://support.ptc.com/help/wnc/r12.0.2.0/en/#page/Windchill_Help_Center%2FPlanMgmtProjectProgramExecutionRef.html%23
We are using automatic execution plan.
During the project running, we need to add some missed out activities.
Thank you.
Hi @Sathish_Rosario
PetrH
@Helena
Thank you for your suggestion.
It works well.
