Creo Drawing Appears Different in Creo View
Please help me understand why my Creo drawings are not appearing the same as my drawing representation in Creo View. I have multiple drawings of parts and assemblies that are experiencing this issue. Here are the descriptions of the Creo View versions that are messed up: The first has removed all of the dimensions. The second and third, which are assemblies, have added rogue BOM balloons. In one drawing, the BOM balloon is linked to an item, but does not appear on the Creo side. In the other, the balloon appears to be unrelated to anything and has a "..." inside. The fourth drawing has removed dimensions and even hole features from the creo part. I don't think that this is a layer issue or an issue even within Creo, but the rogue balloon linked to an item makes me suspicious. I actually think that it is a representations/annotations issue in Windchill. From the drawing information window, I found Representations/Annotations under the content tab. In this window there is a default representation linked to Creo View and includes the undesirable view. It does not appear that I am able to modify this representation. I can only delete it, but after I do that then I have no Creo View option for the drawing at all. Is anyone familiar with this issue? How do I get Creo View to display the exact same information that I am showing on my .drw file?
I appreciate any help that you may be able to provide,
Nick
