Creo View 4.2 - Unable to annotate PDF representation
mastachef
My current setup is as follows:
Windchill PDMLink M030-CSP06
Creo View 4.2
Adobe Reader 2017
Everything seems to work. I was able to create a representation in Windchill (PDF) and view it in Creo View. However, I am not able to annotate the PDF file in Creo View. I checked the setting for Reader and mad sure 'Enable Protected Mode' was deselected and I am still unable to annotate.
- Is there anything I am missing that needs to be done?
- Would installing Creo View PDF Reviewer be the solution?
RandyJones
20-Turquoise
(To:mastachef)
I have this and it works:
Windchill 11.0 M030-CPS11
Creo View 5.0 F000
Adobe Acrobat DC 2015
You need at least Adobe Acrobat (the next step above Reader I think) in order to annotate a pdf in Creo View.
RandyJones
20-Turquoise
(To:mastachef)
Creo View 5.0 F000
mastachef
(To:RandyJones)
Thank you for your response. I looked over the matrices and it seems like my configuration should work. I will try to update and see if anything works.
Any other suggestions for troubleshooting? Has anyone resolved this without upgrading their setup?
mastachef
(To:RandyJones)
Thank you for your suggestion.
I was able to upgrade to Adobe Acrobat DC and that seemed to do the trick. I was also able to install Creo View 3.1 and I was still able to to annotate PDF representations.
It would seem that the biggest issue is the version of the Adobe product which is installed.
