My company is preparing to migrate to Windchill 10. Now that we have it installed onto a server a couple of us have been running it through it's paces and we've noted a problem when Creo View Lite opens a MS Word document. We get the following report: "Creo (TM) View-productview.exe has stopped working".
I'm providing the problem details below-
Problem signature:
Problem Event Name: APPCRASH
Application Name: productview.exe
Application Version: 10.0.30.14
Application Timestamp: 4f05c67e
Fault Module Name: USER32.dll
Fault Module Version: 6.1.7601.17514
Fault Module Timestamp: 4ce7c9f1
Exception Code: c0000005
Exception Offset: 0000000000013bbd
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: fc3e
Additional Information 2: fc3ea2da2aad1522277a3dffb762f350
Additional Information 3: 0d95
Additional Information 4: 0d9593393d4f820a7efd803b9ef38697
Any suggestions?
Browsers used are Internet Explorer 9 and Firefox 11.0
Any assistance would be greatly appreciated.
Stacy
Okay, problem identified and corrected, see explanation below.
We noted when Creo View Lite was initiated it was attempting to load a plug in for Adobe. Given this we decided to uninstall certain Adobe components beginning with Adobe Reader X. After it's removal Creo View Lite opens the file as expected with not crashes.
VladimirN- thanks for the suggestion.
Try to contact with PTC's technical support by creating new "Case", here: "Log a New Case".
You're welcome. I am glad that you solve your problem.
