Deleteing objects: object references object that was removed from the system.
Chris17
I am stuck with deleting objects due to the following error:
Referential integrity violations occurred for this operation:
Object "EPMDescribe Link - wt.epm.structure.EPMDescribeLink:37206516" references the object "wt.epm.EPMDocument:37180131" that was removed from the system.
Any hints how to proceed?
Thank you in advance for your support!
Best regards
Chris
TomU
(To:Chris17)
It seems like an EPM Document (CAD document) was deleted from the system but the link back to the WT Part was not.  (Not sure how that happens...)  I wonder if deleting the WT Part would correct the problem.
https://www.ptc.com/en/support/article?n=CS23768
https://www.ptc.com/en/support/article?n=CS292752
https://www.ptc.com/en/support/article?n=CS53764
Hello Chris,
Were you able to fix the above error while Deleting EPMDocument?
Br,
Ganesh
